2008 Ultra No start
2008 Ultra No start
I have a 2008 Ultra.I did have it running about a year ago now there is no power when you turn the ignition on.No check engine light,key symbol flashes.I have done the following so far:
1)New battery
2)New FOB batteries
3)new fuses/same relays,switched relays around though.Cleaned battery terminals.
4)Swapped the old TSSM with a new one
5)Bought a TSM,to eliminate the TSSM,but cant reprogram it because no engine light.
6)Tried checking codes from odometer but like i said no engine light.No communication with ECM it seems.
I R & R'd the ignition switch a while ago and am about to remove it to see if I misaligned the switch.
Any input would be appreciated.Thanks!Bruce
1)New battery
2)New FOB batteries
Brewster (05-09-2016)
You may need the original module to get it unlocked.
You can also call the HD Tech line 1-800-258-2464 and they maybe able to help.
Good Luck
Bill
