Resetting TSSM Issues
Old Sep 22, 2016 | 01:40 PM
jtaylor0326's Avatar
jtaylor0326
Stage I
Question Resetting TSSM Issues
I apologize in advance for the wall of text coming at you. I'll make this as short as possible.
I have installed LED lighting all around (finally!) on my 2013 FLHRC. My issue is that when I turn my blinker on (either side), my alarm light (the little key) also flashes. I've narrowed down the security codes to B1121 and B1122. I've been told that I need to reset my TSSM. Problem is, that this procedure
http://www.***********.com/electrica...procedure.html
doesn't work for me. I get to step 4, and something completely different happens. There is no flash of the indicator, but I can see what I believe is the PIN for the TSSM. Is there a "newer" procedure out there that I can't find through Google? I'm not sure this is something I need to be overly concerned with - the turn signals work like they're supposed to. But the warning light is there for a reason, and I'd rather not have to take my bike to the stealership.
Things to note:
I have load balancers installed according to directions.
All connections are tight, and clean.
They are Kuryakyn, and I have the Panacea tail light.
I have cleared the codes, but they come right back as soon as I turn either turn signal on.
Thanks in advance!
slipvayne9278
Apr 25, 2019 08:58 AM
akodust
Sep 12, 2015 01:22 PM
ricomtzjr
May 23, 2013 11:13 PM
raw
Sep 4, 2008 06:33 AM
Bigbird
Dec 20, 2006 02:32 PM
