Charging system gone bad
A few months ago I was having battery issues - the battery wouldn't hold a charge. Since the bike is an 08 (sportster 1200) I figured replacing the battery was in order.
I took it on several rides around 50 miles each and noticed that the new battery was not turning over as quickly as I would have expected. I bought a charger and hooked it up overnight and it started right up. I took it out for a longer ride, around 100 miles, and it died about 95 mile in. Towed it home looked at the battery and it was toast - it molded to the shape of the battery compartment. The bike also had a strong smell coming from the side that the oil tank is on.
Brought it to the dealer and they said it was a bad voltage regulator, so now I have a new battery (again) and a new voltage regulator. It seemed ok until about a week ago, I turned the throttle in second gear and the battery and engine light went on and stayed on.
I got a multimeter and tested the stator high 30's to low 40's for volts at idle and 51 when I bring it up to around 2K rpm.
I think that the stator might be the issue. Thoughts?
