117 SE Low Rider S Battery
Looking for some suggestions on battery or upgrading the starter for the 117. Just purchased the bike with only 670 miles on the clock with the 117 upgrade. This is a 2016. When I picked up the bike the battery had been replaced with a WSU battery which was garbage and barely had enough CCA to turn the motor over. Long story short ran it by the dealer to make sure the ACRs were on which they were. Dealer stated the stock HD battery at 310 CCA should be good enough for the 117 which I put back in and seems to start better. Wondering if this will be true and the HD battery will hold out since it's a lot higher compression or should I upgrade the starter too?
© 2024 MH Sub I, LLC dba Internet Brands
