Fuse Block
02-05-2017, 01:17 PM
Fuse Block
I'm working on my 2008 Electra Glide, I replaced my 96" with a 103" I'm hooking up ACR wires, I'm using the the Harley kit, it's say to pull the fuel pump wire out of its location and move it to another location then put the new wires in the fuse block. But I can't get the wire to pull out the back of the block I know there is a release but I can't seem to find it. Has anyone removed wires out of the fuse block and if so how did you do it? Any help would be great, thanks in advance
02-05-2017, 05:42 PM
As I recall …
First pull that orange thing off.
(Harley calls these secondary locks. They just pry off from the front.)
Then look inside and push on the tang, then pull wire out the back.
When putting in you will hear the tang click into place, then push that orange lock back in.
02-06-2017, 05:15 AM
Yes I took out the orange locks then I looked for the tang but don't understand what the tang is or looks like
02-06-2017, 11:02 AM
02-06-2017, 04:59 PM
That is what the service manual was showing, I had worked at for awhile and gave up before I did something that I was going to regret lol, I tried it again today and it finally released, thanks for the input
02-07-2017, 06:05 PM
WOW! I cannot believe that HD would actually publish instructions to repair wiring and connectors using crap like Xacto knives and safety pins to work on connector contacts...VERY shade tree amateur, not professional at all!
dmarion
07-08-2015 10:05 PM
matt76cmich
2014-2023 Touring Models
04-14-2015 05:34 PM
niels74
03-02-2015 10:41 AM
ShAwTWiN
11-11-2011 11:49 AM
maddog76
10-22-2010 01:54 PM
