1980 Lowrider Shovelhead lights go out when front brake pressed
Just bought this 1980 Lowrider Shovel from my girlfriends cousin. When you hit the front brake the headlight and taillight go out for about 30 seconds, and then you can hear a click and the lights come back on. Any ideas what could be causing this? Wiring is completely foreign to me.
Problems like this are often mechanical, so set aside your concerns about wiring! As Dan points out you probably have an electrical short caused by a bare or damaged wire. Your bike when new came with circuit breakers, not fuses, so the click you hear when applying the brake is the breaker tripping out.
The problem could be as simple as a trapped wire inside the r/h handlebar switch housing. The wires can put up a fight when installing the switches, so start there. I suggest you disconnect the battery first! Follow the wiring from there, checking carefully as you go.
Received 47,744 Likes
Well, they were when the bike was built...
But...the bike is 37 years old, no telling what has been done to the electrical system.
OP needs to remove the dash, fuel tanks, and the seat, then inspect all the wiring.
Wondering if the OP is listening.....
