2002 RK Jump Start and now issues
Alright guys reporting in. Nothing out of order and all tested as suggested. Even swapped the relays. Taking the dash off and headlamp out and starting to test harness there. Someone suggested maybe one half of the ignition switch got fried. Thanks to everyone thus far I do appreciate the help.
Another update. So I never tested the relay right behind the battery that is rubber mounted. The wiring diagram shows 3 not sure why there are 2 under the left panel and there is 1 under the right side cover. This one behind the battery seems to actually be the power relay and not the one under the right side cover. Well the one behind the battery is burnt to a crisp on pin/blade 87. I will replace tomorrow and update. I think I may have found my problem.
So the power relay was cooked. Replaced it and everything is now fine. Except the battery is now dead. Oh well. New one should be here Wednesday. Thanks everyone this place is a valuable resource and I really appreciate everyone's responses. Now to start posting about fixing my Springer. UGH.
