Harley garage door opener kit w/ chamberlain or LiftMaster myq openers fix
If you have this wall unit then you are in the same situation.
I just installed my harley garage door opener kit (flash your brights to open your garage) and it was kind of a pain and the instructions really sucked as usual.
After getting it all set up and working, I come to find out that my garage door opener doesn't work with standard door bell style wall mounted opener buttons. They myQ fancy one with the wifi and digital display can only be opened by their fancy wall opener.
So so I wasn't going to give up after doing all that wiring on my bike and paying $140. Side note, in my opinion for $140 it shouldn't need a damn receiver unit. You should just be able to program it to your garage door.
The general idea idea was to solder it to a regular clicker. When you flash your brights it sends a signal to the receiver unit that you have to plug into the wall and the receiver unit closes the circuit to the garage door opener just like manually pushing the button.
So so here are some pictures on how to do that.
The following 3 users liked this post by gennacide:
I want to thank gennacide for the pictures and the post. I had traded my Ultra Classic for the 2018 CVO Street Glide. In the past, I simply put the remote for the garage door opener in the windshield bag of the Ultra. With the Street Glide, I purchased the HD garage door opener kit. I was frustrated that I could not get it to work with the Liftmaster (Chamberlain) garage door opener. I reached out to Chamberlain and I received the email back informing me they don't support the HD garage door opener. I also called the company who installed the garage door and opener and they were unable to help. So...I began watching Youtube videos and then I came across this forum and found many different threads relating to my problem. I found this option to be the best for me and IT WORKED! I did my happy dance...rode for several miles...then tried it again to make sure I wasn't dreaming. Sure enough...The garage door opened as it was supposed to! Thank you for this post and the others that I read.
Phil
Phil
sportglide (01-14-2018)
I used gennacide's technique yesterday, worked great. The only thing I did different was soldier the wires from the receiver to the back of the remote circuit board instead of the front of the button and I was able to fit the remote circuit board inside of the the HD receiver. I'll just have to change the battery every few years.
