2016 fuel gauge
Old 06-07-2017, 08:34 AM
1trashybiker's Avatar
1trashybiker
1trashybiker is offline
Stage I
Default 2016 fuel gauge
street glide fuel gauge not working low rng lights up onspeedo panel gauge moves to top of low fuel marker but does not go any farther
Old 06-10-2017, 10:21 AM
acchd's Avatar
acchd
acchd is offline
Probably the fuel sender inside gas tank is bad. You can get to sender through popping off tank console and retaining ring. Without removing sender you can unplug it from top access of tank and test and measure resistance across the sender to see it's changing on ohm meter as move float arm like it should.
Old 06-10-2017, 10:35 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,467 Likes on 4,598 Posts
Deleted
Old 06-10-2017, 10:38 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Instead of wasting your effort here, get on the phone to the dealer and let them handle this warranty issue.
Old 06-13-2017, 02:57 AM
hog-doc's Avatar
hog-doc
hog-doc is offline
Saw a few where the sender popped off the mount in the tank and would not read correctly...5 minute fix!
FormerPointer
Electrical/Lighting/Alarm
05-11-2015 09:29 AM
BKDeuce
04-03-2015 03:48 PM
Neil
06-09-2013 09:29 PM
karlmdog
03-19-2010 11:56 PM
ultravista
Exhaust System Topics
03-02-2006 11:23 AM
Quick Reply: 2016 fuel gauge
