Fused Block Added to Ultra Classic
I felt I had too many connections at the positive terminal of the battery so I added a 4 terminal fused block. This allowed me to remove the inline fuses further cleaning up the battery area. Basically an 8 AWG wire from the battery terminal to the fuse block which has a BT 4180 amp, trickle charger, and wire for heated gear connected to it. Hope this helps anyone who is thinking of doing the same thing.
Battery before fuse block install.
The battery after connections were moved to the fuse block. Perfect place to mount the fuse block which was under the left side cover below the seat. The battery is located just behind it.
cwickgo9 (07-28-2017)
Thanks. As much money we have in these bikes they are an investment so makes sense to take care of them even if it's things like this that make life a little easier.
A friend said an optional speaker for the alarm mounts in the area I used for the block.
The connection for the charger and heated gear is one ring terminal as I doubled them up and crimped them together. I think the ring terminal was sized for 12 gauge wire and it came with the fused block. I couldn't use it since I was using an 8 gauge wire for the fuse block.
dafrisco (07-28-2017)
tennisailor
02-02-2015 10:46 PM
