Spedo/Tacho meter problem on 2016 Roadster
Hi,
my dealer in Italy replaced the intrument in warranty for a dial problem, but after replacement the back light remains on also during daylight (it doesn't change) and the tachometer into digital window doesn't exist !
The dealer connect the pc and checks the ECM but the digital tachometer it is hide!
The digital tacho works well and also every lamps inside.
Only daylight illumination mode and digital tachometer doesen't work properly.
The dealer take time to investigate and leave me with these problems.
The spare parts is exactly the same P/N.
Can you suggest me some solutions.
Thanks
Derio
Thanks
Derio
