i installed Radiantz LED turn signals on my 2016 Wide Glide front and rear, all lights come on as running lights and look great. The issue I'm having is the right front turn signal won't flash and the indicator blinks fast as if a bulb were out. The left front, right rear and left rear all flash just fine and the indicator doesn't flash too fast or anything. I swapped LED's right front to left front and vice versa, the right front still won't flash. Put the halogen bulb back in and it flashes fine. Any ideas?
Thanks, i did try that and it got the indicators to sync up with the turn signals...except for the right front which didn't and still doesn't flash at all...it's pretty wild, halogen bulb works, LED works as a running light just won't flash...
Remove that bulb turn on the signal and slowly reinstall it. The pigtail in the socket could be slightly rotated. Look at the contacts on the old versus new bulb.
Good call, the pig tail was too deep in the socket and wasn't making good contact. Pulled the reflector out along with the pig tail and reinstalled, all good now. Thanks for the help
