Need voltage regulator help please
I have a 2012 softail deluxe with a bad voltage regulator. Harley says I need a part #74540-11. Other sources say the #74540-08 will fit and may even be an upgrade from the 74540-11 (which was recalled in 2012). The specs look the same, but the 74540-08 is a lot cheaper and appears to be much easier to find from multiple sources. Can anyone help me out? Thanks
The 74540-11 is the correct part for your bike. The 74540-08 is an earlier version. It probably was for an 08 or later model. The 08 may work, but it may not.
Drag Specialties makes an aftermarket item for your bike, but they look almost as expensive as the OEM, and who knows where or how well it is made. Ebay has some used ones on there for considerably less than new.
White Knight 04
09-30-2009 07:15 PM
