Garage door opener help
i just purchased an aftermarket LED headlight and my garage door opener stopped working. I spliced it in the same way it was on the factory light. The garage opener will work when the headlight is not plugged in. When I plug in the light works but not the opener. Any advice would be appreciated.
I will try that. I think I'd have to tap into something that uses a momentary switch though. The opener uses the high beam switch. I suppose I could use the horn.
***UPDATE***
i started checking everything with a circuit tester and found that when I disengage the high beam, the power does not immediately terminate, it sort of fades off. This must be messing with the opener. Still looking for ideas to outsmart this thing.
***UPDATE***
