2014 SGS....Security light on--ABS light on--Cruise light on not working
Can anyone tell me what these three things have in common? I replaced the tree which means I had to raise the inner fairing and remove the bars. Which means I had to disconnect some plugs and disturb the wiring. And the plan is to pull the fairing outer and go over everything with my good glasses to see if I've missed or forked up anything. Which I obviously have.
Bike cranks and runs fine and everything seems to work aside from the cruise. ABS seems to work in the driveway anyway.
Ideas????
Ideas????
Well....as in most cases this was all operator error. The cable for the front wheel sensor was unplugged at the neck which explained the ABS light on. And my front brake lever was not installed correctly so my brake lights were always on. That fixed the cruise and the red security light.
All is happy now and the 9 degree raked tree was soooooo worth the effort and money. And I added heated grips to boot!
Andrew5305
09-19-2018 10:21 AM
Motown_HOG
03-07-2008 08:00 PM
