What is this and where can I get one?
Get out your voltmeter.
Let us know when you are ready to actually troubleshoot.
While your problem isn't with the voltage regulator, I just thought I would share a little info on them in case you run into charging issues in the future, which most of us do at some point. Voltage regulators and stators are usually replaced together. Because a problem with one can sometimes cause the other to go bad. So what ends up happening in many cases where only one is replaced is they just keep going back and forth ruining each other. A bit of a pain & cost to replace both, but it evades this nightmare that many of us have gone through. Best of luck & ride safe.
Not sure if you have corrected your issue yet but thought I would mention a couple things you might want to consider. First is that you stated it is a 'custom' chopper - meaning it most likely does not have standard factory wiring and/or a schematic diagram available. There's always the possibility that it may not have been wired correctly from the gate. Not trying to say anything bad about the builder, just that I have seen those sorts of issues many times on custom stuff. Was it working properly and then failed or was it not working correctly when you got the bike and now you are trying to fix it? Just something to think about & hopefully lead you to the problem.
Not in my experience! But that is why we encourage members to diagnose the problem, for which we have Stickies over in the Tech Electrical section. The only failed regulator I've had in over 40 years of riding Harleys came several years after the stator went out. In fact those are my only failures and were on the same bike.
HoggyMtnBreakdown
09-07-2011 10:19 PM
Seaweed1929
12-04-2009 08:32 PM
