Sportster Low Fuel Light On Constant
Got a 2014 XL1200C and the low fuel light stays on constantly. I've searched all over here and don't find an answer for this exact situation. Is there a typical culprit for this? To my knowledge the tank hasn't been off. Bike does have V&H fuelpak, Big Radius exhaust and SE heavy breather on it but stock bars so I don't think anything's been messed with that's related. Maybe sending unit? Bad float? Electrical short? Help!
So after much searching on XLforums and a little here, I see quite a few owners have this problem (thx H-D). I removed the tank and pump and testing the low fuel sensor with an ohm meter shows no difference whether the float is up or down. But I don't see what would activate anything anyway since it's just a plastic float on a plastic stem - no metal unless the plastic float has some magnetic quality. Since I have to replace the sensor, I figured may as well get the fuel sensor kit ,pn 61200008A, since that's the only replacement H-D shows in their online catalog. However, there's much ambiguity regarding it's function with the stock speedo/tach. I don't want to buy the digital speedo/analog tach if the new fuel sensor will provide more function with the stock speedo. It's my understanding that it will provide the fuel range but not the level. This is from owners as dealers seem to be overall unknowledgeable about the system especially when replacing the speedo/tach also, including not being able to figure out that you can't replace the speedo prior to the sensor and some dealer ads for the sensor even state it's for bikes equipped with the digital speedo (thx again H-D). Are there others that can confirm more function with the upgraded sensor with the stock speedo on the 2014? Knowing responses much appreciated!
If you look at the base of the fuel level sending unit you will find some metal pads that serve as a potentiometer to change the resistance that goes for the fuel gauge and the fuel low light going to the speedometer. The upgraded speedometers will also show fuel level on them as well, if you are getting no change on the 2 pins that service the fuel level sending unit then most likely check the base of the sending unit, you may find a disconnect there.
Well the low fuel sensor float does have some magnetic properties I found, but no matter. I'm upgrading from the low fuel sensor to the fuel level sensor, so I'm still unsure of the additional functions when used with the stock speedo on the 2014. I believe it will just add fuel range, which will make it the same as my Fat Bob so that's cool, but wondering if anyone else has done this and what they found?
Fuel low signal is just the way the speedometer interprets the signal from the fuel level sending unit. There is no other optional item that can be used for the fuel level sending unit. The same signal goes from the sending unit to the speedometer and the fuel gauge. It is just with the stock speedometer the resistance value hits a certain threshold it activates the idiot light. Not sure where you got the magnetic properties idea from but it doesn't exist.
Low fuel light
Spoiler
shineybike
10-10-2011 05:12 PM
