I own a 1998 roadking police model. Here lately the headlight is not working and the Hi bean indicator is lit up in the dash panel.
ALSO. the hi beam/low beam switch don't work.
These issues are intermittent ....might be fine the next time I ride it.
Anyone have a idea as to where I might start trying to figure this one out?
check the bulb end first since it is the easiest. look for loose/burned terminations and then use test light or meter to check circuit operation. if circuit does not function correctly, before getting to bar switch, check fusing and terminations, if good, proceed to bar switch.
