Can wires.
Old 12-10-2017, 06:56 PM
puzzled1's Avatar
puzzled1
puzzled1 is offline
Default Can wires.
2018 CVO Road Glide. I am removing the entire factory stereo system minus the head unit. While reading the wiring diagram I see there are several Can Hi and Can Low wires. I'm guessing these are Canbus wires. Wanting to remove the wires from the harness which I won't be using I'm not sure what to do with the Can wires. Just about every plug I'd like to remove has two pair of these white twisted wires in them. All of the new stereo equipment will self supported, I'm not taping into anything existing. What can I do or what needs to be done with these wires?
Old 12-11-2017, 12:24 PM
larsfum's Avatar
larsfum
larsfum is offline
I would not remove any wires from a Canbus system. Bundle them up, and tuck them away. The other upside to that is that later down the road someone can reinstall the OEM equipment without having to undo your "fix".
Old 12-11-2017, 12:35 PM
puzzled1's Avatar
puzzled1
puzzled1 is offline
My issue is they are attached to plugs and I want to remove the plugs as they serve no purpose. I'm not concerned with what the next person may or may not do. Not being rude there just I'm building the bike for me, not the next guy.
Old 12-11-2017, 02:39 PM
bustert's Avatar
bustert
bustert is offline
there is no issue removing the wires for a component but you may have to have the ecm reprogrammed so as to ignore the missing pieces. the ecm is in a continuous loop and if it expects to see something and it is not there, a code will be generated.
another point is that in the auto world, the stereo is married to the ecm so it becomes worthless, does hd do this???
Old 12-11-2017, 03:44 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
I've never owned a Canbus bike and it sounds as if you haven't either! How about getting the FSM to check how it works and how to modify it?
Old 12-12-2017, 10:39 PM
TomCop's Avatar
TomCop
TomCop is offline
Just remove the wires and plugs. You will generate fault codes (time out) as the programmed components are not found. It will not stop the rest from functioning. You will have a red light enabled on your speedo, indicating that there is something that needs your attention. As you did it yourself, no need to pay attention to. Of course when something else goes wrong you will not be notified as the red indicator is always on.
Success!
Old 12-21-2017, 08:32 AM
puzzled1's Avatar
puzzled1
puzzled1 is offline
Not only do I own the service manual I own the electrical manual the CVO supplement and the parts manual.
Old 12-21-2017, 08:33 AM
puzzled1's Avatar
puzzled1
puzzled1 is offline
Success!
Thank you. That is what I did. I removed all the pieces I no longer need. Do you know if the red service light can be reset or cleared even if by the dealership? I don't know if I have a red light yet as I have not fired the bike up.
Old 12-21-2017, 08:35 AM
puzzled1's Avatar
puzzled1
puzzled1 is offline
Thank you. I am okay with hitting the dealership if need be. I spoke with someone the other day with first-hand knowledge of this and he removed the entire system minus the main cambus wire from his bike without issue. I'm hoping for the same results.
Jack shaw
04-16-2017 04:52 PM
dmarion
07-08-2015 10:05 PM
06SGWA
09-12-2014 08:07 AM
Varooom
02-21-2012 11:53 AM
Softbutt
05-08-2006 05:34 PM
Quick Reply: Can wires.
