Hi & Lo beam together
Old 04-25-2018, 03:18 PM
Daddio's Avatar
Daddio
Daddio is offline
Default Hi & Lo beam together
Is it possible to wire a Harley-Davidson Daymaker projection headlight so both the high beam and low beam stay lit up together when you select Hi from the control switch?
Old 04-25-2018, 03:29 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,198 Likes on 11,126 Posts
It seems the circuitry internal to the Daymaker prevent both hi and lo turning on at the same time. I even tried bench testing it, by wiring lonand hi directly to 12v...no workey. If I has known that, I would have gone with another type. I have the Vision X on my Road King, and both come on with that.
Old 04-25-2018, 04:44 PM
Daddio's Avatar
Daddio
Daddio is offline
I had heard it was one mod that couldn't be done on the projection version of the Daymaker. I thought somebody here could confirm it. Once the hi beam mode is selected no matter how you feed it the power it defaults to cutting out the low beam.
dynagliding
03-05-2012 04:26 AM
Route66rider
05-26-2011 08:38 PM
brad594
05-26-2011 12:38 AM
smithbrl
03-20-2011 10:17 AM
Whisper365
General Topics/Tech Tips
10-26-2010 11:04 PM
Quick Reply: Hi & Lo beam together
