Flashing turn indicators
I wish someone would answer you since my 01 Softail is doing the same thing. I have a manual, but I can't find anything about how to clear a code. I get 4 million threads when I try to do a search, and nothing I can find applies to this issue.
https://www.hdforums.com/forum/touri...nal-flash.html
Did not fix MY problem, but I got some other stuff to look at.
Here is what it took to clear out the code in my 01 Softail
Turn ignition on and immediately turn on 4 way flashers (it will stop and flash 6 times for the code and then pick back up)
After 15 seconds turn the ignition switch to off. The flashers will continue to work.
After 10 or 15 seconds more, turn the ignition switch back on and wait another 10-15 seconds with the flashers on and the ignition on. Turn flashers off and turn ignition off.
That worked for me after a bit of trial and error.
Desperado (06-20-2018)
uktzero
12-14-2007 11:19 AM
