1995 Ultra Fuse box location
I had the same problem and was ready to tear into my fairing for the fuses when I found the answer to this question.
Check your high/low beam switch.
I found in this model bike, if the high beam switch is on when you first crank it up, the spots will not come on.
Sounds weird, I know. But I turned it to low bean before cranking and the spots came on.
You can also find this answer on other forums.
Good luck.
Jim
Good luck.
Jim
