Emergency flasher staying on
Received 47,790 Likes
Not on the 2015 RG. The switch is the top half of the start button, The bike must be turned on to turn the flashers off.
Hazard Warning: Pressing the top of the switch (triangle symbol) operates the four-way flashers. This system allows a stranded motorcycle to be left in the four-way flashing mode and secured until help is found.
- With the ignition switch in the IGNITION or ACCESSORY position, press the hazard warning switch (triangle) to activate the four-way flashers.
- Turn the ignition switch to OFF (with security system fob present). Lock the ignition switch. The four-way flashers continue flashing for two hours or until the rider cancels operation. The security system will arm (on equipped vehicles).
- To cancel, turn the ignition switch to IGNITION or ACCESSORY (with security system fob present). Press the hazard warning switch (triangle) to cancel the flashers
The following 2 users liked this post by 14GuineaPig:
kevinb62 (08-12-2018),
Uncle Larry (08-12-2018)
Thank You Guinea Pig I finally figured it out. I thought I had pushed both of them while
cleaning the scoot this evening. when I tried to push both at the same time and it didn’t turn off I was
dumbfounded. I usually have my owners manual handy but seem to have misplaced it in the house.
Thanks for your reply,
Kevin
Kevin
