U0001 Code
Old 08-18-2018, 08:16 PM
DaddyKnuck's Avatar
DaddyKnuck
DaddyKnuck is offline
Received 1,658 Likes on 943 Posts
Default U0001 Code
My '13 FLD starts and runs great. Everything works as far as electrics are concerned. However, I get a check engine light pretty frequently. It will come on and go off after several seconds. The only DTC is U001, CAN BUS fault. Any ideas? The only recent change was a new angled taillight lens that required me to switch to a LED bulb. Could this cause the problem?
Thanks.
Old 08-19-2018, 12:02 AM
mmesa005's Avatar
mmesa005
mmesa005 is offline
DaddyKnuck (08-19-2018)
Old 08-19-2018, 03:33 PM
Zanthamos's Avatar
Zanthamos
Zanthamos is offline
You may have hit the nail right in the head, switch the bulb back and see what you get.
DaddyKnuck (08-21-2018)
Old 08-21-2018, 09:21 PM
DaddyKnuck's Avatar
DaddyKnuck
Thank's guys for the help. I followed the instructions to have the BCM "learn" the new LED bulb. I thought that had fixed it, but after about a 50 miles ride it started coming on again. I tried swapping the LED bulb for the original. Again, the light was off for a good long ride, and then started to come on again. I swapped back to the LED because the tail light lens was getting hot. This afternoon I "taught" the system about the LED being back in place. For good measure I went through all the other light functions. We'll see tomorrow AM. The CEL will come on for only a few seconds and then go out again. Always the same generic code. Very frustrating, but I think more of an annoyance than a serious problem. I hope anyways.
Old 08-30-2018, 05:18 AM
TomCop's Avatar
TomCop
TomCop is offline
An Error popping up and vanishing again, is most of the time related to a bad connection or a pinched wire.
DaddyKnuck
05-25-2019 07:46 AM
elfnyc
07-07-2016 03:19 PM
Dustmaker
08-06-2008 09:38 PM
odog
05-13-2008 10:28 AM
LeadSlinger0311
04-11-2008 10:39 PM
Quick Reply: U0001 Code
