05 Electr Glide Cruise Control won’t engage
That style shouldn't matter as it's merely a pulse width modifier and should get rpm information from the injector signal itself. While I doubt it will make a difference, you could simply plug the harness back to the injectors and retest. I was looking to see if there was a device between the harness and the ECM. By testing this way you could be sure that no add on devices are affecting the issue. At least that eliminates another variable.
