Hi guys. For a friend. I searched but couldn't find an answer. Can he run LEDs in the front and incandescent (standard) bulbs in the back? Is a load stabilizer required (even if he did all four to LEDs)? Thanks
In trying out LEDs on mine, I did the 2 rear bulbs only and flashed normal rate. I then installed on the front and got the quick flash problem and errors, added load balance resistors today and solved. So yes, should be able to do 2 LEDs only without issue (at least on 2013 and earlier)
