Hi all my name is Bill I’m from Wales part of the Uk,I have a smart alarm problem removed the battery to charge hooked it back on the bike and the alarm indicators went off. I don’t have the security pin so I tried to recover the assigned pin via the ignition switch and indicator switch to show pin in the odometer but nothing came up alarm still sounding off new batteries installed in fobs. still cannot disarm the alarm so cannot start the bike,Harley dealer said they are the only people that can solve it but there 50 miles away any help would be appreciated
Hi Zanthamos Thanks for replying to my post I have managed to sort it out now looks like the connection to the unit had come loose while I was taking the battery out of the battery tray but your reply was well appreciated There are some real good people in this forum
Hi yes I did try that but nothing, I filddled with the wiring at the alarm sound box under the bike and suddenly alarm stopped and I was able to start the bike but I still cannot pull the bike security code up in the odometer So Many Thanks for your very helpful advice Cheers Bill
Go through your owners manual under the HD Factory Security, there should be a section on how to set the security code, if the FOB is working then you should be able to set the code.
