HD AGM battery sat for a year...
I have a stock AGM bagger battery that was removed from a 2016 bike a year ago. The battery was six months old when pulled, fully charged, set aside and forgotten about. Yesterday, I checked it and it read 11.9v after sitting without a charger for that year. I put a 3amp battery tender brand charger on it, and it read fully charged after several hours. After sitting overnight off the charger it reads 12.45v.
Could the the battery be ok after sitting for that long?
I picked up a 2015 that has an aftermarket battery and I noticed the neg terminal is cracked, so I’l like to use this battery if possible. What do you think?
Didn’t have access to a tester, and the cheap aftermarket battery in there had a cracked terminal so I put the HD battery in for now. It started the bike right up, which is good. I’ll try a few consecutive starts next. I figure if it’ll start five times in a row it will be ok until I can get a Yuasa GYZ32HL delivered from Amazon. I’ll leave it on a tender as well.
Received 4,614 Likes
If it took hours to fully charge, it's probably ok. It's when they charge up in 5 minutes that the battery's toast, they'll discharge just as fast, no capacity left. Putting the battery through a few work cycles sometimes recovers capacity, too, you may see the resting voltage increase some more after a few rides.
Mchad (11-26-2018)
Mchad (11-28-2018)
Iron lHorse
02-20-2019 01:25 PM
