Delayed Crank When Starting
I have a 1999 Ultra Classic with 49k miles. When I turn on the ignition and press the starter button, there is a .5-1 second delay before the engine cranks. I do not get a click noise. This only happens when the engine is cold. When the engine is warm it fires right up.
I installed a new Deka AGM battery and I made sure the battery cables are clean and tight at both ends. This didn’t help. Could this problem be the starter solenoid or the starter relay?
Where is the starter relay located on a ’99 Ultra? My manual doesn’t show location.
ss90
01-16-2010 08:04 PM
