95 FLHTC electra glide fuse box diagram?
#51
Ok grounded antenna and push pull wiggle test findings: no radio in any results but it feels like the antenna connector is just to big for the internal Male connector of antenna. I made sure I had a good ground running to frame and mainly battery. I also had the thread keep spinning which actually ended up coming off so I body pressed it back on with the pavements assistance. The internal thread that screws into the antenna was rusty looking a little bit so I used QD cleaner and sanded it. I haven't seen the antenna wire under the tank but frame to fairing and rear tank to antenna all seems solid. What are your thoughts sir?
#53
#54
Guienna yes they are standard antenna Jack's.
#55
Well I went under the tank and through the fairing again. Every single connector and test I can perform. My volt gauge is actually accurate now but I have absolutely nothing to the head now. Just the dimmer and that's it. Not sure what else to do at this point but I'm exhausted and ready to throw fairing back on. I also did run a ground straight from battery to ground the radio but no difference .
#57
I ran my multi meter of the fuses suspecting the same thing and oddly enough none of the fuses had juice besides the radio memory 1 amp. Didnt see any fuses actually blown but something fishy is definitely going on. I had to call it a night and leave my bike cause I was told I had a big seizure so the ole ladies driving me home as we speak.
