ALARM Problem on Street 500
Hello i've bought a street 500 for daily ride and bought a used bike. and just realized that the alarm system is not working.
when i'm turning the ign on the alarm wont armed. but when i'm eject the main fuse the siren is still chirpin loud. its also chirp when I'm entering the wrong pin while i put the fob away
anybody has a clue on it?
thank you
thank you
Hi D'nugroho, Welcome to HD Forums. I am reading your post and not exactly sure what your actual issue is. From what I see I have deduced the following.
Is this a Harley alarm? Mine has security but the only way to get a "chirp" is by adding additional equipment.
When you have the fob, does the bike start and run properly?
Good luck and Ride Safe!
- When you turn the ignition to on, the alarm is disarmed
- If you eject the main fuse, the alarm chirps
- If you enter the wrong code the alarm chirps
creasama (02-08-2019)
If you don't have the owners manual you can download a copy free from the H-D website. I suggest you go to the H-D USA site, then the Owners tab, where you can use your VIN. That may confirm if your bike had an alarm when new (not all bikes do), also the book will provide guidance on how your alarm works and the procedure for removing the main fuse.
is the alarm module need to replace or there's some sensors thats not workin?
He said it chirps when he enters the wrong pin or when he pulls the main fuse but not when he moves the bike or when the fob disengages the alarm. I don't know when they are supposed to chirp, mine just has the blinking lights and no chirp at all. Maybe the it was added to the bike or they come standard on the Street in Indonesia. I think he needs a owners manual. The bike may be in transport mode.
it's solved thanks for all the response
KiloGolf4
08-26-2012 06:10 PM
