Another dang brake light issue...
On the first schematic at the bottom where it says "See Fig B-22 " go to the last schematic that shows the lights. Book says connector 257 is under the Left Side Cover and you found connector 7 under the seat on top of the fender. If you check the signal from the TSSM or brake relay before the added components you can tell if the problem is with the flasher and anything else added. For example if nothing is connected between 257 and 7 then at 7A if you turn on the Left turn signal the V wire at position 3 should pulse 12V. to ground, all other wires should be 0. Hit the Brake r/y will show steady 12V. Not sure if front turns might be in mix or not.
Good luck
Good luck
Blue box looks like a Custom Dynamics Signal Stabilizer and the red box looks like a Smart Tripple Play unit from CD as well. If you just disconnect the tripple play from the harness and the stabilizer and plug the stabilizer into the harness, check to see what you get. I would bet it is the tripple play that is frazzled.
Vernal (02-12-2019)
Our hours are Monday through Thursday, from 8:30am to Noon and from 1:00pm to 5:30pm, EST, and Friday from 9:30am to Noon and from 1:00pm to 5:30pm EST.
__________________
Custom Dynamics® - EVERYTHING To Light Up Your Ride!®
15 Cypress Drive
Youngsville, NC 27596
sales@customdynamics.com
https://www.customdynamics.com
http://blog.customdynamics.com
Review Custom Dynamics
Phone: 800-382-1388
15 Cypress Drive
Phone: 800-382-1388
Vernal (02-12-2019)
Ok, latest update...
Didn’t call CD today, will try tomorrow if we still haven’t figured it out.
With flasher out of loop, brake light still on, blinkers off. Relay clicks when hit front switch, but not when I hit rear switch. Disconnect rear switch & no change. Opened clam shell, but haven’t gotten switched out of housing yet & trying not to just start cutting wires. R/Y has 12v constant with ignition on.
