Another dang brake light issue...
02-12-2019, 08:49 PM
The 09 did have a recall on the rear brake light switch
02-12-2019, 09:45 PM
If you unplug the relay does the brake light stay on?
Do you have ABS
02-12-2019, 10:31 PM
Quote:
Originally Posted by
Vernal
Do you have ABS
yes & yes
02-12-2019, 10:33 PM
14GuineaPig
Thanks! I’ll follow up on that too
02-12-2019, 10:52 PM
If you unplug the relay and the brake light stays on I don’t think either switch is bad. With the relay out check for voltage at the socket on 2b the R/Y it must be hot. Now you need to find out where the short is, unplug 7 and see if it goes away.
02-13-2019, 09:08 AM
Vernal!!!!! Thanks brother, you helped me out BIG TIME!!! I really appreciate it!
Finally found the problem after Vernal’s last post. I guess I need to raise it back up a little bit. Apparently a 3” drop is too much...
Dfszme
03-11-2017 11:25 AM
IornStreetBob
06-02-2015 10:47 PM
kaiyohea
Electrical/Lighting/Alarm
03-06-2014 05:22 AM
baka1969
10-30-2013 05:57 PM
Calico Jack
11-17-2011 06:29 PM
