Garage Door Opener Setup
Hi everyone. I’ve been looking through and enjoying many of the posts on this forum. While browsing yesterday I noticed many to do with setting up your bikes to open the garage doors. Harley’s method, although works well is pretty expensive. I came across the below product a few years ago. I installed it on my previous harley. Its very affordable and works great. I haven’t seen anyone make mention of this on the forum. Hopefully this will help all of you.
I installed it on my 18 Street Glide Special. Easy install and works great.
http://www.autoswitch.com/as7g.php
71on72 (02-23-2019)
You know, a trip reset switch from a pre-CanBUS model bike could be used in a normal or a key chain transmitter mounted under the dash or in the faring. This method wold only require a 1/2" hole to be drilled and you wire the momentary switch to the switch points on the key chain transmitter push button. You can then find a place to put it and it will be weather resistant. Clear RTV will weather seal the transmitter.
idid mine 4 years ago.
