2012 Ultra Limited wont start
Old 04-08-2019, 12:06 PM
Androidjv191's Avatar
Androidjv191
Androidjv191 is offline
Stage I
Default 2012 Ultra Limited wont start
Hi New here, Thank you for your help
My 2012 Ultra Limited is on a battery tender when I am not riding. Bike started fine two weeks ago for just firing it up in the garage. Could not ride then as there was still snow on the ground.
Yesterday I unplugged the battery tender and turned on the ingintion hit the started button and the thing went dead. Nothing, no lights dead!
Plugged in the charger again and left it over night. Today nothing dead. no lights zip!
Is my battery dead after a long cold winter in an unheated garage?,
or did i blow the main fuse?
Thanks from Ontario Canada
Old 04-08-2019, 07:38 PM
Vernal's Avatar
Vernal
Vernal is offline
Received 7,284 Likes on 1,903 Posts
Welcome to the Forum from Utah.
Put your voltmeter on the battery terminals and see what you have, should be 12.8 or a bit higher. If the battery is low take it out and put it on a charger and have it load tested. Then check for voltage at the tender lead, it is fused so if you don't see battery voltage the fuse may be bad.
Old 04-08-2019, 08:07 PM
76_shovel's Avatar
76_shovel
76_shovel is offline
what he said ^^^
Old 04-15-2019, 09:28 AM
jmeyer58's Avatar
jmeyer58
jmeyer58 is offline
If you hit the starter button and everything goes dead I would bet a bad connection, probably at the battery.
Old 04-16-2019, 11:24 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,482 Likes on 4,605 Posts
You can`t answer this question yourself?
Pull the battery, fully charge it and take it to an auto parts store and have it load tested.
Clean all electrical connections before installing a known good battery.
Old 04-17-2019, 05:58 PM
Zerk's Avatar
Zerk
Zerk is offline
Before I bother travelling around with the battery, check the connections, then put a volt meter on the battery.
Old 04-24-2019, 09:15 AM
Dan89FLSTC's Avatar
Dan89FLSTC
A volt meter may tell you the battery is low, but it will not tell you if it is good working condition, only a load test will do that.
Pantera99
03-03-2019 04:57 PM
dinolo24
11-14-2014 09:53 AM
TexSport2013
01-23-2014 04:47 AM
harleyfiremedic
11-23-2012 11:23 AM
P Diddy
08-30-2012 09:21 PM
Quick Reply: 2012 Ultra Limited wont start
