Charging issues
Old Jun 26, 2019 | 01:27 PM
Fmsplr's Avatar
Fmsplr
1st Gear
Default Charging issues
So my 03 ultra classic anniv. Edition i just bought a few months ago, running great but i noticed my fuel gage going wako stuck on full but the low fuel light comes on and i have half a tank so i stop and the everything goes back to normal this happens a few times in a matter of a week or so. No biggie untill i remove the front cowling to investigate a weak speaker and adjust my handle bars. Took half a day but went pretty smooth until i went to ride, in a matter of 4 miles +- the idle went a little crazy running up and not comming down and my battery went completely dead. Had the radio on all day the battery was old so i bought a new one thinking problem solved riigghht? Took it out and the 140.00 battery died in 4 or 5 miles. Did the exact same thing idle going crazy i could see the volts dropping. I dont think this is connected but also my screamin eagle exhaust baffle on one side broke and is loose inside the can for about a weak or so
Thats were im at i looked at all wiring except the front cowling no obvious problems no blown fuses could i have done something inadvertently to something behind the front cowling? Missed a connection? Or caused something to short.
This is my only transportation any help as to what to look for would be most appreciated. I paid cash for this so im a little strapped trying not to just start replacing parts till its fixed. Thanks in advance
Old Jun 27, 2019 | 06:51 AM
Vernal's Avatar
Vernal
Welcome to the Forum from Utah.
Charge your battery up and perform the following tests:
Testing:
Connectors and cables should be checked and cleaned first. Loose and corroded connectors, terminals and grounds can cause high resistance, impeding current flow. Check cables for broken or rubbed insulation and check continuity to make sure the conductor is not broken inside the insulation.
Coating connectors with dielectric grease will keep moisture out and reduce corrosion.
Use the schematics in the HD Electrical Diagnostic or Service manual to determine the location of additional connectors.
Battery testing:
First check and clean battery terminals, Battery cables and ground connections. To check cables, disconnect one end and Ohm out, wiggle while testing. Cables can and will corrode and the evidence can be concealed under the insulation.
If you are unsure of the battery’s condition charge it fully and take it to an auto parts store and have it load tested.
Voltmeter test:
Connect voltmeter positive to positive terminal on battery and voltmeter negative to battery negative terminal.
12.7 v = 100% charge
12.6 v = 75%
12.3 v = 50%
12.0 v = 25%
11.8 v = 0%
Watch the battery voltage when you start the bike, if a fully charged battery falls below 9.6 volts it’s time to replace it.
If a well charged battery runs down if the bike sits for a short time perform a current draw test. Set your meter to read 10 amps current. Pull your main fuse and insert the meter leads. Here’s a list of components and what current they will draw in milli amps, 1/1000 of an amp) from the 2015 manual:
LHCM 0.5
RHCM 0.5
Speedometer/ IM 0.5
Regulator 1.0
ABS 1.0
BCM 1.0
ECM 1.0
Security Siren 20.0
Radio 0.5
Amplifier 0.5
CB Module 0.5
If the Battery passes all tests check the charging system.
Charging System Testing:
Volt meter set to DCV 20V scale or higher.
With the bike in neutral and voltmeter attached to the battery, start the engine and rev to 3,000 rpm. If the voltage measures 13V – 14.7V the charging system is operating properly. If less than 13V test the Stator first. If Greater than 15.5V test the Voltage Regulator.
Stator testing
Turn the bike off and disconnect the Stator from the Voltage Regulator.
Testing a 3 phase Stator, (A single phase stator is tested in the same manner but the plug will only have 2 sockets).
The end of the connector from the stator has 3 sockets. Set your meter to ohms and connect one lead to the battery negative. With the other lead make contact with the conductors inside each socket. You are checking for a grounded coil winding, each socket should show an open circuit to ground, no continuity.
Now take both meter leads and check resistance between each of the three sockets, 1-2, 2-3 and 1-3. The resistance should be 0.1 – 0.3 ohm.
Next check the Stator’s AC output. Set the meter to ACV 100V scale. With the Stator unplugged from the VR and the bike in neutral, start the bike. Run the bike at 2,000 rpm and check the Stator output between sockets 1-2, 2-3 and 1-3. The voltage should read approximately 32-46 Volts AC, for the 50 amp Stator. Stators with other Amp ratings will be similar.
If the Stator continuity tests to ground and Phase to Phase are good but the output is not the Rotor may be bad.
One other indication that the stator may be bad is if your primary oil smells like a burnt circuit board.
Voltage Regulator Testing
Voltage readings of 15.5V and higher test wire from VR negative to battery negative, if less than 0.5 ohm replace Voltage Regulator.
If the output is less than 13V from the Voltage Regulator to the battery and the Stator output is good, disconnect the output cable from the VR to the Battery. Check continuity between the Voltage Regulator Positive wire and the battery Positive and the negative wire and battery negative. Repair or replace cable if needed. If the cables are good and the Stator tested well replace the Voltage Regulator.
Robert Wayne Nichols
Electrical/Lighting/Alarm
Apr 16, 2019 08:48 PM
Fscott4
Sep 1, 2018 11:30 AM
alee18
Jan 8, 2018 01:34 PM
Bxmarauder
Nov 8, 2016 07:11 AM
nobody05
Sep 21, 2016 08:26 PM
