Intermittent Starter Problems
Old Oct 15, 2019 | 10:58 AM
Wayward1200's Avatar
Wayward1200
2nd Gear
Default Intermittent Starter Problems
Intermittent starter problems. Push the starter button, starter relay clicks, all gauges die. Cycle ignition switch and the lights come back on, start switch will kill everything again.
When I jump the solenoid (has worked in the past to start the bike), the starter now engages and remains engaged (the bike doesn't start). The kill switch and ignition switch won't turn off or disengage the starter. I had to remove the battery cable to turn off the starter.
Starter was replaced by a Harley dealership. I would rather not spend more money at the dealership if I can avoid it and I don't want to just keep replacing parts hoping something will work.
Any ideas? Short in the solenoid, even though it's new? Starter button? Kill switch? Ignition switch? What kind of tests can I run?
Old Nov 13, 2019 | 07:15 AM
86glider's Avatar
86glider
I know this is a month old but.... first off, what yr and model?Hitting the start button, it will cut out lights and everything else to give full power to start.Check battery and the sticky in the EVO section under dreaded click.Get back to us I'm sure we can help keep you away from the dealer.
Old Nov 14, 2019 | 08:59 AM
Wayward1200
2nd Gear
I forgot the basics, didn’t I? 2001 Road King.
I replaced the Start/Kill switches and haven’t had a problem since. It still doesn’t make sense to me logically. The switches tested ok multiple times. When I was trying to find the problem and the starter solenoid clicked it must have also kicked out the circuit breaker at the same time because all lights and gauges remained off even when starter button was no longer pressed. They turned back on when I cycled the ignition switch. I still don’t understand why, when I jumped the solenoid, that the starter remained engaged even when I turned off the ignition. Anyway, the problem is now fixed. I appreciate your input 86glider.
Old Nov 15, 2019 | 09:24 PM
86glider's Avatar
86glider
Good to hear ur back on the road.
drrot
Aug 15, 2019 12:20 PM
Pech
Apr 23, 2018 04:04 PM
jim70
Electrical/Lighting/Alarm
Nov 16, 2015 05:21 PM
IA DPE
EVO
Aug 26, 2014 08:11 PM
75hdxlh1000
Aug 10, 2012 09:09 AM
