No idea what this is... help please
Old Jan 4, 2020 | 11:16 AM
Bshakes's Avatar
Bshakes
Default No idea what this is... help please
So bike had been running fine. I pulled my tank and was going to check wires and hoses for potential weak points and found this. Its definitely blown, and I have no clue what it is. Any help would be appreciated. Thanks guys.
Old Jan 4, 2020 | 11:17 AM
Bshakes's Avatar
Bshakes
It's tied into the main harness.
Old Jan 4, 2020 | 11:27 AM
Kawickrice's Avatar
Kawickrice
What year bike?
Old Jan 4, 2020 | 11:48 AM
Bshakes's Avatar
Bshakes
Originally Posted by Kawickrice
What year bike?
98 softail sorry.
Old Jan 4, 2020 | 11:51 AM
Bshakes's Avatar
Bshakes
I had to replace the regulator because it was over charging burnt up a battery and burnt out my brights. So I think the blow out may have happened then.
Old Jan 4, 2020 | 01:26 PM
RDHIGH's Avatar
RDHIGH
Could be a module for HID headlight- or maybe a module for rear run/brake light? It doesnt look factory..... any markings on it at all? You could follow the wires to where they terminate to get a better idea of the function.
Old Jan 4, 2020 | 03:45 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Follow the wires and see where they are connected, what color wires (on the main harness) does the gizmo tie into?
Old Jan 4, 2020 | 05:05 PM
bustert's Avatar
bustert
could be a load block for leds.
Old Jan 4, 2020 | 08:11 PM
Bshakes's Avatar
Bshakes
No markings or numbers at all. Three wires. The black wire ties in with gounds. Brown wire ties in with three brown wires leading to instrument lights, right front turn signal, and an unused female plug. Blue wire ties into 3 purple wires leading to instrument lights, left front turn signal, and the same unused female plug. Talk about a pain the wires are almost all over sprayed black. That made tracing the wires a pain. Thanks for being patient all.
Old Jan 4, 2020 | 08:30 PM
RDHIGH's Avatar
RDHIGH
Im gonna go with Busert- and say load equalizer for leds. The violet leads to one turn sig- brown the other turn sig.
