Electrical puzzle
Old Jan 12, 2023 | 08:38 PM
carbjoy's Avatar
carbjoy
1st Gear
Default Electrical puzzle
Greetings to all the bros here..
Road bike, everything working great, to gym. When I came out, fuel gauge and speedo not working. Everything else is cherry. Visibly checked all fuses and they look good, no breaks. Didn't have light tester with me. Important to re-check with tester?
This problem is above my pay grade. Clue might be the dumb-*** move I made. After installing and riding for a couple weeks with neon glow lights under bike at front and back, had a pair of hot wires (red) disconnect. I "accidentally" reconnected them to a ground wire in-line with T-Tap wire connector.
I own a multimeter, light tester and just need some direction on trouble-shooting this thing out.
Feel free to take pot-shots at me for the smooth move
Thanks
Old Jan 13, 2023 | 07:39 AM
jbarr1's Avatar
jbarr1
Visual inspection of fuses will not be sufficient. Get rid of those useless wire taps. JMO.
Old Jan 13, 2023 | 08:14 AM
Vernal's Avatar
Vernal
06 Fatboy?
Check the instrument fuse.
Old Jan 13, 2023 | 08:18 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
First up reverse everything by disconnecting your wiring. Make sure everything then works correctly on the bike.
Any wiring I have done on my bike I make reversible. I create Y connectors at applicable connectors so that I can unplug my wiring and return the bike to stock.
I have added led accent lights and used the accessory connector on the bike. I didn't use the HD harness but they do make a daisy chain arrangement for accessory into that plug on a Sportster.
On bikes that have a CAN DLC connector one of those pins is switched power and HD makes a lead for that to daisy chain devices to.
Old Jan 17, 2023 | 09:01 AM
carbjoy's Avatar
carbjoy
1st Gear
Ok. Thanks for input. See attached pic. I undid the lights and removed the wire taps. Tested all fuses with light tester and they checked out good. Where do I go from here?
Old Jan 17, 2023 | 09:10 AM
Andy from Sandy
Check the wires on your extra lights for any sign of damage. If you have a 12volt source check them off the bike first. Maybe a small 9volt battery will do.
If everything on the bike is working perfectly then make sure to pick the correct wires for positive and negative and connect up your lights again.
See if you can find a supply that doesn't involve using those crimp splice things. I suspect as you have used them you have compromised the insulation on some wires in the loom?
Old Jan 17, 2023 | 09:31 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Just because a test light illuminates does not mean the correct current is in the circuit.
Put the test light back into the toolbox, and get out the multimeter.
Test lights are for hooking up trailer lights.
Old Jan 17, 2023 | 09:57 AM
TriGeezer's Avatar
TriGeezer
Your malfunctions may or may not be related to the mods you made. I’ve been bitten several times by coincidences.
- closely examine the wires that you spliced into. By design those taps damage the wires, and if you used too small tap for the wires then you could have severed them. As well they can chew the wires up due to the vibration on the bike.
- after you disconnect everything you added, and examined the tapped wires, check all the fuses with a multi meter.
- if all the above checks out, then it sounds like you are in the coincidence territory. You’ll need to get the factory service Manuel, and reference the schematics to figure out where it’s screwed up. If two gauges are scrued up, it’s likely a ground or power that is common to both of these.
By the way, I’m very happy with using those heated solder shrink connector things. Especially when there is enough room to slide on regular best shrink and shrink it on top after melting the solder. I’ve never had one go bad on motorcycles or boats. Make sure you use the smallest that will fit over the wires. I twist the wires together, then slide the connector with the solder over the wires, then heat with a heat gun until the solder melts, and the shrink tube shrinks.
I’m ok putting two wires in one or both sides. But, if I need to connect more than that I daisy chain them.
Old Jan 17, 2023 | 10:00 AM
jake24lt's Avatar
jake24lt
Thanks
And after these bounce around for a while, they saw through the wire. Even worse if they are exposed to the elements. Do you yourself a favor, and toss these.
Old Jan 17, 2023 | 11:58 AM
Vernal's Avatar
Vernal
Did you use one of your connectors on the Orange wire? Does your Neutral light come on?
