engine won't cut off
I have a 96 F150 and when I turn the ignition switch to the off position the truck keeps running. I am able to stop the truck by pulling the fuse to the fuel pump. when the truck is stopped, all internal power is still applied. Overnight, I have to pull the battery cable to prevent draining the battery.
The ignition switch was faulty. I could remove the key from any position (start, on, acc...). I have replaced the ignition switch, but it did not fix my problem. I believe that there is another problem inside the steering column. Can anyone help? _______________________________ Acai Berry Juice Powder Fruit Children with Enzymes and Autism in California Inspiration Sign Language Pin Bracelets permanente make up |
| All times are GMT -5. The time now is 09:08 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
