AMP Multi-Lock Crimp Tool? Referrals or recommendations?
I want to make some wiring changes and need to deal with the pins and plastic connectors like are on the ends of the turn signal wires and are the connections for the wiring harness ... I think they are called AMP Multi-Lock connectors
I've done some work and crimped them with needle nose pliers and solder. They work fine, but its a pain. Would really like to find a crimping tool but not sure if what I found will work ... The OEM tool is really expensive and not an option for me.
Does anyone have experience with either of these tools or another you can point me to?
http://www.ebay.com/itm/Open-Barrel-...#ht_1808wt_704
http://www.mouser.com/ProductDetail/...4Ze%2FcEpWw%3D
thanks in advance - vou
i bought one similar too the first one you have listed from an electronics place i found online. they were inexpensive, thats why i got them before installing my aux lights and aux power connections on my SG. i cant remember the place but any how they worked out good for what i needed them to accomplish.they worked on the pin ends and female ends equally as well.
RoadGrinder
01-28-2015 09:27 PM
voudoujoe
Electrical/Lighting/Alarm
07-07-2012 07:46 PM
amp, cheap, connections, connector, connectors, crimp, crimper, crimpers, crimping, davidson, electrical, harley, harleydavidson, multilock, pin, tool
