Chamberlain / Liftmaster compatible with Harley garage door opener
Hey everybody -- just a quick note to say that from now until December 31st, everything is 20% off for the holidays. If you're unable to make your HD opener receiver to work with your LiftMaster, Chamberlain or AssureLink opener (or any other device that interfaces with it for that matter), or if you need a replacement for a dead HD receiver for far less than from HD, now is the time to make your move!
Check out the complete product line at www.CreativeAccessSolutions.com
Last edited by spepin; 11-24-2015 at 08:54 AM. Reason: removing an inaccurate statement
For those of you that have installed the Harley opener inside a steel building or in a house that has metal siding, you've probably notice that the range of the transmitter is poor to say the least. Mine is installed in a steel building so I did a modification to the antenna to increase the range. Here's how to do the modification from a thread I wrote on the subject if you're interested.
https://www.hdforums.com/forum/elect...ification.html
Looks to me like they still sell it http://www.harley-davidson.com/store...-door-receiver
I like the price of the receiver you offer much better, I did buy one from you a while back for my other garage, works great and half the price.
Glad it's working for you -- I do like the antenna extension you did -- looks very well thought out and clean. Thanks again for your business!
I purchased this
So I have the Harley Davidson garage door opener that interfaces with the headlight switch on my bike. Works great - or at least it did until I replaced my old opener with a new Chamberlain / Liftmaster opener with MyQ technology (the MyQ technology allows you to interface additional lighting controls with the opener, as well as control/monitor it through your smart phone or via the internet). Since the wall control uses a new smart interface (there is a built-in LCD display that shows time/temperature and allows for programming), the simple dry contact output of the Harley receiver is no longer compatible.
I have developed a modification which adds a Security+2.0 MyQ interface which restores full functionality of the Harley garage door opener interface, and it installs within the case of the original receiver. Note that the Crafstman AssureLink openers are functionally identical to the Chamberlain/Liftmaster, so this modification applies to those as well.
The modification is available as a service (where the buyer sends their existing receiver to me for modification) Also, I'm currently offering brand new receivers with the Security+2.0 MyQ interface already built in, and also as an inline module add-on. Currently, the modification service is listed at $50 which includes parts, labor, testing and a 90 day warranty. Brand new OEM (non Harley branded, but otherwise identical in appearance and operation), are $75 (which is the same as the list price for the Harley Davidson 91562-01 receiver, but includes the modification already installed). An inline module runs $55. Also available is a universal module, which is the same as the inline module, but it has longer leads with tinned wires instead of the connectors, to connect virtually any legacy equipment with relay outputs.
You can check out the modification service and inline modules here:
www.creativeaccesssolutions.com
Steve.
P.S. I've attached some pics of what goes into the modification so you see that it's not just a waste of money. In the first set of photos, the small board is the Security+2.0 MyQ interface. No other external modifications need to be made. The second set of photos show the inline module. With the inline module, no need to ship your receiver to me (unless it's not working and you want me to check it out, or you want the stealth look of everything being inside the receiver with nothing external). Either way, it's just plug-n-play.
Steve.
Thanks for your business, Jim! Once again, my apologies for the delay in getting it to you. If the original shipment shows up, just refuse it and have them send it back. Cheers!
