Stripped
Old Jan 17, 2015 | 10:22 PM
rcrankin's Avatar
rcrankin
Default Stripped
Friend of mine was buttoning up his install of the SE cam chain tensioner plate on his 2003 Anniversary 88 inch. The torque wrench was set at 100 inch labs and the threads in 2 holes stripped before reaching full torque. One hole is for the cam plate itself and the other is for the cover. Because of the wall thickness, I'm not sure these can be drilled and retapped. Any info/ideas are appreciated and thanks in advance.
Old Jan 18, 2015 | 07:41 AM
prodrag1320's Avatar
prodrag1320
ide check the torque wrench for proper calibration.the hole in the case can be repaired with a insert,but ide get another plate
Old Jan 18, 2015 | 10:44 AM
djl's Avatar
djl
As Kirby says, you can use a Helicoil to repair the threads in both holes; the exception would be if the hole for the cam plate fastener is the one at the locator dowel. I have stripped that hole before and I ran the next size tap through that hole, 5/16" IIRC, enlarged the hole in the cam plate for the larger fastener and it worked fine.
Old Jan 18, 2015 | 08:33 PM
rcrankin's Avatar
rcrankin
Never considered helicoils, but they look like a good fix. Thanks.
Old Jan 18, 2015 | 10:47 PM
slyedog's Avatar
slyedog
Just use caution when breaking the tab off the heli coil so it doesn't get lost in the cam chest. Did you follow fastening sequence when doing the install?
Old Jan 18, 2015 | 10:56 PM
Uncle Larry's Avatar
Uncle Larry
Timeserts are another option and easier to use or a "novice" ... Good Luck with your scooter.
http://www.timesert.com/
Old Jan 19, 2015 | 12:46 PM
dforeid's Avatar
dforeid
I would get another plate also.
ntraindavefl
Engine Mechanical Topics
Aug 29, 2018 03:33 PM
Glasso
Aug 2, 2018 02:22 PM
roundy
Nov 5, 2015 10:26 AM
mhartiga
Exhaust System Topics
Jan 25, 2013 03:39 PM
BulldogBiker
Jun 30, 2012 08:48 PM
