Woods TW555
Old Jan 24, 2015 | 10:40 PM
saz's Avatar
saz
Originally Posted by Oldschool79sporty
I can get the cam pretty cheap so that was my angle. I have true duals, PC & stage 1 already installed and wanted to bump it up a little w/o a lot of major work. We do a lot of traveling so wanted a little more get up that's all. I am one to red light race with guys too so I won't lie that I'd like to thump their 103's red to red! So if I do the cams which adj rods are best, alum or steel? S&S or Andrews?
Look around a bit. You can find cams from some of the builders in a bundled package or amazon, ebay etc for very good prices......
Old Jan 29, 2015 | 08:03 PM
Oldschool79sporty's Avatar
Oldschool79sporty
3rd Gear
Ok, so I bit the bullet and bought the Woods TW-555, S&S quickee adj rods and tubes, torrington inner cam bearings and all the gaskets, o-rings, etc a man could want. Tearing down this weekend and hoping I can find a canned map at Powercommander to hold me till I can dyno it! Got a cooler full of beer chilling so if I can't ride at least I can get drunk and wallow in misery.
Old Feb 2, 2015 | 03:57 AM
bklynbob's Avatar
bklynbob
I see 103/106/107 in your future. You're gonna have to crank up the compression and lower your gearing..........
Old Feb 2, 2015 | 08:49 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Scott,
Is the S&S kit rods and tubes or a complete cam install kit with gaskets, o-rings, etc...?
The pushrod/tube kit is seperate part number, from the cam install kit.
Scott
Old Feb 8, 2015 | 07:15 PM
Oldschool79sporty
3rd Gear
Default Tw-555 update
Installed the Woods TW-555 cams, S&S Quickee Adj. Push Rods, S&S Hyd Lifters and replaced inner cam bearings and all the o-rings on the oil pump etc....From around 2750rpm to the rev limiter, hold on cause she will flat run! Pulls like a mf'er all the way through, and acts like she wants more! I am using a canned map from Dynojet till I can get it on the dyno, map 818-105. Pleased so far, but I see a 103" or 107" upgrade in my future, lol! Took around 3 hours to do start to finish. A lot easier than I expected but then again most things are if you got everything on hand. Thanks for the input from all that posted, I'll keep you updated and post a dyno sheet after I tune her.
Old Feb 10, 2015 | 09:02 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Default glad to hear your smilin. ....
They are a real good cam. One that you can use for future mods as well... love livin in the woods....
bernietg
Feb 20, 2013 10:24 PM
Dan33klein
Feb 19, 2013 02:54 PM
jlasoftail
Exhaust System Topics
Sep 14, 2011 06:01 AM
bigdork
Oct 5, 2010 07:57 PM
tiiiim2
11
Apr 15, 2007 12:41 AM
