SE Sage IV lifter question
2015 Limited Low.
Stage IV with SE 585 cams, SE perfect fit pushrods, SE lifters. Having lifter noise when cold. Been thinking of S&S Premium. Would the pushrods be good or should I use S&S? I do all my own work and really not an issue using either adjustable or perfect fit.
Thanks in advance for the input
I could definitely be a bad lifter making the noise on cold start up...it's because it's bleeding down and there's no oil in it until the bikes running for a bit...I know because it happened to me..twice lol. As for the s and s lifters I'm using the standards and let think a lot of people do to with no issues. If you feel the need and have the extra money then get the premiums...for me I figured I could get the standards and adjustable pushrods for a little bit more money than just the premiums alone.
Se lifter are crap
Had 2 different sets of Harley lifters both tapped. The last set c series were even worse than the b s Best move I made was getting a set of s&s standards Both lifters I tried of the Harley ones were used with adjustable push rods set to .140 which is 3 turns on se rods. The last set of c lifter clacked like crazy cold or hot. When hot once and a while at idle they were so bled down rockers hammered unless u hit throttle. Put a set of s&s. Talk about quiet all I hear now is whirling sound of engine. The hole for oil indeed on the c lifter is about half the size of oil inlet on the s&s lifter. Get a set of s$s lifter. Adjustable push rods. Just find out what thread pitch per inch they are made with the s$s rods may not be 3/8X24 pitch like se ones
We found that .140" spec years ago, talking into account good lifter load even at full thermal expansion.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
