Cam suggestion for 14 RK
The higher gears do make the engine work a little harder. The gear selection shouldn't matter as much as the RPM's that you are running.
The Andrews 57H's have gotten good press as just a bolt in cam as well as a few others.
Are you considering any head work? I will let those more knowledgeable about the subject chime in on the head work but from what I have seen on the dyno charts is head work that compliments the cam you are going to run can extend and flatten the curve out letting the engine pull longer into the higher RPM range.
If you have a wethead then the 57 will be a great bolt in for sure, remember that the compression on a wethead is 10.1 and 9.7 on the air cooled engines which will make the 57 just a tad bit softer but would still work, especially with a good 2-n-1 exhaust combo. Another great bolt in is the andrews 48 or the Woods 222's. Here's my chart on the 57's comparing the different exhaust combo I went with now which is a Rush Wrath.
A Wood 6-6 would be a very good choice.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
