Pushrod removal?
Pushrod removal?
Picked up a 2009 street glide and I'm removing some motor parts for Powder Coat. The bike has Andrews 37H cams (chain) and Andrews EZ install adjustable steel pushrods. Since I am removing both upper and lower rocker boxes, is it possible to just pull the pushrods out from the top instead of collapsing them? I know each cylinder has to be on the base circle before removal and I do have a service manual. Just trying to avoid the whole turning the nuts, counting the flats, etc... I also drained all of the fluids three weeks ago in preparation for this. Would the lifters have bled down or would they still be pumped up? Thanks in advance
I would readjust, whether removed from top or bottom. However, if you plan to remove them from the top, make sure you put each pushrod back on the lifter it came from. You will also have to loosen the rocker support plate to get enough clearance to remove the pushrods so make sure both valves are fully closed and springs unloaded.
I was afraid you guys were going to say that. Lol The rocker arm support plate will be off anyway as I am going to Powder Coat the lower box as well. Another thing I am curious about, I'm going to be using all Harley OEM gaskets and seals. Should I replace all the bolts holding the rocker boxes to the heads or can I reuse the old ones? Being in the head for 30,000 miles I'm sure they've seen some heat. I assume to make sure all the oil is out of the bolt holes and possibly chase the threads to clean them? Or is this just overkill ?
Thanks DJL. Got the new stamped breathers on order. May even vent to the atmosphere as well. I do not have a thread chaser though, And was thinking about buying a set. Do you think it's really necessary? Or maybe just run a Q-tip down there to make sure there's no residual oil?
Adjusting the pushrods isn't much different than adjusting the rocker arms on a Small Block Chevy, It is just in a different place. Counting flats is just a convenient reference point. It all boils down to finding "0" lash, adding a specified amount of preload to the lifter and locking it down. The amount of turns on the adjuster will be directly related to the thread pitch. Make sure you know what thread pitch is on your pushrods and how much preload your particular lifters like. Then you will know where to set the adjustment to make everything happy.
I can't think of one good reason that they need to be re-adjusted. You aren't pulling the heads. Nor shaving them. Not changing head gasket thickness. Not spin dropping the jugs for deck height. Not changing valves stem protrusion or seats. You get the idea. The only possible difference would be rocker box to head, gasket thickness difference. Can't imagine that being much if any.
Why would you re-adjust the pushrods? Just bored?
