Disconnect Automatic Compression releases?
Old Mar 23, 2016 | 06:17 PM
swampking's Avatar
swampking
Default Disconnect Automatic Compression releases?
I have a set of S&S EZ Start Cams I would like to try out on my 2012 Road Glide with a 103. Can I simply disconnect the ACRs to use the EZ start cams. Will I get any codes?
Old Mar 23, 2016 | 09:26 PM
misfitJason's Avatar
misfitJason
You can disconnect them. I don't know about codes though
Old Mar 23, 2016 | 09:33 PM
Tedwilliams09's Avatar
Tedwilliams09
Will your tuner allow you to turn them off?
I know my screamin eagle will.
Old Mar 24, 2016 | 07:24 AM
kishstl's Avatar
kishstl
If you have a cam and ACR's alread, why are you wanting EZ start cams? Not flaming, just wondering.
Old Mar 24, 2016 | 10:04 AM
djl's Avatar
djl
So, you already have the EZ start cams? I assume that you are concerned that there may be starting issues with the EZ starts and ACRs? I don't think so; it should start easy with no issues. Anyway, the ACRs can be turned off with some fuel management systems or you can have the dealer turn them off if necessary.
Old Mar 24, 2016 | 03:40 PM
GibsonSG's Avatar
GibsonSG
If you simply unplug the ACR's the ECU/ECM should throw codes. However it shouldn't be a issue for the starting system because the EZ-starts just make it a mechanical process.
...best option is to disable the ACR option via the fuel controller and save the map update.
Old Mar 24, 2016 | 04:35 PM
Tedwilliams09
Why would it hurt to leave the ACR activated??
Old Mar 24, 2016 | 04:37 PM
swampking's Avatar
swampking
I have been told it causes hard starting
Old Mar 24, 2016 | 07:10 PM
joe40x's Avatar
joe40x
I've had mine in for about 6 months and have had no problems...ACR's on and easy start cams...starts right up and no codes.
Old Mar 25, 2016 | 08:55 AM
djl's Avatar
djl
No need to disable the ACRs. IIRC, the ECM controls how much to hold the ACRs open to achieve the required cranking speed, so the ECM will just not open the ACRs as much as it would without the EZ start cams.
michaelhd1340
Apr 6, 2018 12:58 AM
guesscrazy
Engine Mechanical Topics
Sep 5, 2016 05:25 AM
jbrelr21
15
Mar 6, 2015 08:42 PM
xmeter
Aug 24, 2009 08:00 AM
capt42a
Exhaust System Topics
22
Mar 1, 2009 06:46 PM
