Need help. FXDX blown cam bearings (obviously ) blown oil pump
Just bought a 2001 super glide for a real song . It appears to have (one) inner cam bearing blown to bits . Roller bearing journals are OK.
Don't know much about the bike . It came with a box of parts including adjustable pushrods ..
The Oil pump impeller is blown to bits. I can only assume a roller from the bearing got caught in the pump.
Now my questions : I would like to avoid a full case split but I will do what needs to be done. Can anyone speculate what event caused this damage. Is there likely debris all through my motor? Is it possible this event caused the Piston to smash a valve?
Can I flush the crank case , replace the roller bearings and buy a high flow oil pump? Haaalp. Not sure what to do .
My guess would be a hardened bearing roller created that pump issue.
When a new pump is installed, and any of that leftover debris gets in there again, you'll see semi-similar or the same.
You may also see evidence of that on the piston skirts.
Good idea to check pinion shaft T.I.R. while your there.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
