curious. 110ci and 117ci kit questions?
So in light of Harleys new 117ci engine kit i was wondering a couple things. I know if i buy a brand new 2016 Harley with the HO 103 engine i can get the 110ci kit for it . So does that mean i can then get the 117ci for it since its a 110 now. IF so Cant you just go from the 103ci right too the 117ci.?? If not then im guessing the factory Screaming Eagle 110ci is different then just the 110ci kit? I looked at the kits it looks like mainly new uppers and cams for the most part. So whats the real deal??
We use S&S 4 1/8" cylinders here for our clients 117", and 124" engines.
Built 13, 4 1/8" bore engines, here, since mid-December.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
They can't be the same, the spigot on a stock 103 is smaller than the stock 110. The cases for a 110 which has a 4" bore, have been bored to accept that larger spigot. Who knows, maybe the CVO for 2017 will be 117 or 120 and the 103 will be replace with a 110.
The cylinder liner on both the 110 and 117 kits has been replaced with a high strength steel liner with thinner than OEM spigots. The 110" kit is a drop in for the 96" and 103" cases and the 117" kit is a drop in kit for the 110" cases. Downside, if there is one, is that the cylinders cannot be bored. Pretty slick move on the part of the MoCo to grab a share of the bigger bore aftermarket and with a warranty..........
110 stage IV tire shredder
I am a new Harley owner by that I mean that I'm new again on a Harley as I owned a Road Glide and 06 and just bought an 09 Electra Glide.
I come from previous bikes (most recent first) Goldwing, Valkyrie, Boss Hoss, Valkyrie, BMW.
So, I now have this Ultra Classic that I am going to play with. found myself an excellent Harley mechanic (retired) who loves to play.
So, I bought the stage IV kit (Tire Shredder).
Anyone out there now what I will be expecting? Should put out 115lbs of tourque and 115 HP. Should be a fun bike.
Jimmy
Jimmy
I am a new Harley owner by that I mean that I'm new again on a Harley as I owned a Road Glide and 06 and just bought an 09 Electra Glide. I come from previous bikes (most recent first) Goldwing, Valkyrie, Boss Hoss, Valkyrie, BMW.
So, I bought the stage IV kit (Tire Shredder). Anyone out there now what I will be expecting? Should put out 115lbs of tourque and 115 HP. Should be a fun bike.
Jimmy
Jimmy
